REST API reference
Delete an S3 policy configuration
DELETE /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced In: 9.8
Deletes the S3 policy configuration of an SVM.
  • vserver object-store-server policy delete
  • vserver object-store-server policy delete-statement
name
string
path
True
Policy name
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
92405858
Failed to "delete" the "policy" because the operation is only supported on data SVMs.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
