REST API reference
Delete an initiator group
Deletes an initiator group to remove its association with storage resources and protocols, effectively managing access control within your network environment.
HTTP method and endpoint
DELETE /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
  • lun igroup delete
uuid
string
path
True
The unique identifier of the initiator group.
allow_delete_while_mapped
boolean
query
False
Allows the deletion of a mapped initiator group.
Deleting a mapped initiator group means that the LUNs, to which the initiator group is mapped, are no longer available to the initiators. This might cause a disruption in the availability of data.
This parameter should be used with caution.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1254213
The initiator group is mapped to one or more LUNs and allow_delete_while_mapped has not been specified.
5374852
The initiator group does not exist.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
