Delete an initiator group
Deletes an initiator group to remove its association and management within your storage environment. Use this endpoint to manage initiator configurations and streamline resource organization.
HTTP method and endpoint
DELETE /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
lun igroup delete
Learn more
uuid |
string |
path |
True |
The unique identifier of the initiator group. |
allow_delete_while_mapped |
boolean |
query |
False |
Allows the deletion of a mapped initiator group. Deleting a mapped initiator group means that the LUNs, to which the initiator group is mapped, are no longer available to the initiators. This might cause a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254213 |
The initiator group is mapped to one or more LUNs and |
5374852 |
The initiator group does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
