REST API reference
Delete an initiator group
Deletes an initiator group when you no longer need it, freeing up resources and simplifying your system configuration.
HTTP method and endpoint
DELETE /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
  • lun igroup delete
uuid
string
path
True
The unique identifier of the initiator group.
allow_delete_while_mapped
boolean
query
False
Allows the deletion of a mapped initiator group.
Deleting a mapped initiator group means that the LUNs, to which the initiator group is mapped, are no longer available to the initiators. This might cause a disruption in the availability of data.
This parameter should be used with caution.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1254213
The initiator group is mapped to one or more LUNs and allow_delete_while_mapped has not been specified.
5374760
An error was reported by the peer cluster while deleting a replicated initiator group. The specific error will be included as a nested error.
5374852
The initiator group does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
