Retrieve the node configuration in MetroCluster
Retrieves the node configuration in the MetroCluster to access detailed information about the current setup and operational parameters of the nodes involved.
HTTP method and endpoint
GET /cluster/metrocluster/nodes/{node.uuid}
Introduced in
ONTAP 9.8
Related ONTAP Commands
metrocluster node show
node.uuid |
string |
path |
True |
Node UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
automatic_uso |
boolean |
Specifies if automatic unplanned switchover is enabled. |
cluster |
configuration_state |
string |
Configuration state of the node. |
dr_group_id |
integer |
DR Group ID. |
dr_mirroring_state |
string |
State of the DR mirroring configuration. |
dr_operation_state |
string |
State of the DR operation. |
node |
"href": "/api/resourcelink"
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"dr_group_id": 0,
"dr_mirroring_state": "string",
"dr_operation_state": "string",
"node": {
"name": "node1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
