REST API reference
Retrieve the node configuration in MetroCluster
Retrieves the configuration details of a specific node within a MetroCluster environment to review and manage node-specific settings that affect cluster performance and reliability.
HTTP method and endpoint
GET /cluster/metrocluster/nodes/{node.uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the node configuration in the MetroCluster.
  • metrocluster node show
node.uuid
string
path
True
Node UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
automatic_uso
boolean
Specifies if automatic unplanned switchover is enabled.
cluster
cluster
configuration_state
string
Configuration state of the node.
dr_auxiliary_cluster
DR AUX cluster.
dr_auxiliary_partner
AUX partner node.
dr_group_id
integer
DR Group ID.
dr_mirroring_state
string
State of the DR mirroring configuration.
dr_operation_state
string
State of the DR operation.
dr_partner
dr_partner
DR partner node.
dr_partner_cluster
dr_partner_cluster
DR partner cluster.
encryption_enabled
boolean
Indicates if the encryption for NVLog and storage traffic is enabled.
ha_partner
ha_partner
HA partner node.
ha_partner_cluster
ha_partner_cluster
HA partner cluster.
is_mccip
boolean
Indicates whether the configuration type is MCC-IP.
limit_enforcement
string
Indicates if the node object limits are enforced.
node
node
      "href": "/api/resourcelink"
  "cluster": {
    "name": "cluster1",
  "configuration_state": "string",
  "dr_auxiliary_cluster": {
    "name": "cluster1",
  "dr_auxiliary_partner": {
    "name": "node1",
    "system_id": "string",
  "dr_group_id": 0,
  "dr_mirroring_state": "string",
  "dr_operation_state": "string",
  "dr_partner": {
    "name": "node1",
  "dr_partner_cluster": {
    "name": "cluster1",
  "ha_partner": {
    "name": "node1",
  "ha_partner_cluster": {
    "name": "cluster1",
  "limit_enforcement": "string",
  "node": {
    "name": "node1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
cluster
_links
_links
name
string
uuid
string
DR AUX cluster.
_links
_links
name
string
uuid
string
AUX partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner
DR partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner_cluster
DR partner cluster.
_links
_links
name
string
uuid
string
ha_partner
HA partner node.
_links
self_link
name
string
system_id
string
uuid
string
ha_partner_cluster
HA partner cluster.
_links
_links
name
string
uuid
string
node
_links
self_link
name
string
system_id
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
