Retrieve the node configuration in MetroCluster
Retrieves the configuration details of a specific node within a MetroCluster environment to review and manage node-specific settings that affect cluster performance and reliability.
HTTP method and endpoint
GET /cluster/metrocluster/nodes/{node.uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the node configuration in the MetroCluster.
Related ONTAP Commands
metrocluster node show
node.uuid |
string |
path |
True |
Node UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
automatic_uso |
boolean |
Specifies if automatic unplanned switchover is enabled. |
cluster |
configuration_state |
string |
Configuration state of the node. |
dr_auxiliary_cluster |
DR AUX cluster. |
dr_auxiliary_partner |
AUX partner node. |
dr_group_id |
integer |
DR Group ID. |
dr_mirroring_state |
string |
State of the DR mirroring configuration. |
dr_operation_state |
string |
State of the DR operation. |
dr_partner |
DR partner node. |
dr_partner_cluster |
DR partner cluster. |
encryption_enabled |
boolean |
Indicates if the encryption for NVLog and storage traffic is enabled. |
ha_partner |
HA partner node. |
ha_partner_cluster |
HA partner cluster. |
is_mccip |
boolean |
Indicates whether the configuration type is MCC-IP. |
limit_enforcement |
string |
Indicates if the node object limits are enforced. |
node |
"href": "/api/resourcelink"
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"dr_auxiliary_cluster": {
"name": "cluster1",
"dr_auxiliary_partner": {
"name": "node1",
"system_id": "string",
"dr_group_id": 0,
"dr_mirroring_state": "string",
"dr_operation_state": "string",
"dr_partner": {
"name": "node1",
"dr_partner_cluster": {
"name": "cluster1",
"ha_partner": {
"name": "node1",
"ha_partner_cluster": {
"name": "cluster1",
"limit_enforcement": "string",
"node": {
"name": "node1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
DR AUX cluster.
_links |
name |
string |
uuid |
string |
AUX partner node.
_links |
name |
string |
system_id |
string |
uuid |
string |
dr_partner
DR partner node.
_links |
name |
string |
system_id |
string |
uuid |
string |
dr_partner_cluster
DR partner cluster.
_links |
name |
string |
uuid |
string |
ha_partner
HA partner node.
_links |
name |
string |
system_id |
string |
uuid |
string |
ha_partner_cluster
HA partner cluster.
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
system_id |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
