REST API reference
Retrieve the node configuration in MetroCluster
Accesses the node configuration in the MetroCluster to review or manage the current setup of nodes within your cluster.
HTTP method and endpoint
GET /cluster/metrocluster/nodes/{node.uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the node configuration in the MetroCluster.
  • metrocluster node show
node.uuid
string
path
True
Node UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
automatic_uso
boolean
Specifies if automatic unplanned switchover is enabled.
cluster
cluster
configuration_state
string
Configuration state of the node.
dr_auxiliary_cluster
DR AUX cluster.
dr_auxiliary_partner
AUX partner node.
dr_group_id
integer
DR Group ID.
dr_mirroring_state
string
State of the DR mirroring configuration.
dr_operation_state
string
State of the DR operation.
dr_partner
dr_partner
DR partner node.
dr_partner_cluster
dr_partner_cluster
DR partner cluster.
ha_partner
ha_partner
HA partner node.
ha_partner_cluster
ha_partner_cluster
HA partner cluster.
is_mccip
boolean
Indicates whether the configuration type is MCC-IP.
limit_enforcement
string
Indicates if the node object limits are enforced.
node
node
      "href": "/api/resourcelink"
  "cluster": {
    "name": "cluster1",
  "configuration_state": "string",
  "dr_auxiliary_cluster": {
    "name": "cluster1",
  "dr_auxiliary_partner": {
    "name": "node1",
    "system_id": "string",
  "dr_group_id": 0,
  "dr_mirroring_state": "string",
  "dr_operation_state": "string",
  "dr_partner": {
    "name": "node1",
  "dr_partner_cluster": {
    "name": "cluster1",
  "ha_partner": {
    "name": "node1",
  "ha_partner_cluster": {
    "name": "cluster1",
  "limit_enforcement": "string",
  "node": {
    "name": "node1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
cluster
_links
_links
name
string
uuid
string
DR AUX cluster.
_links
_links
name
string
uuid
string
AUX partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner
DR partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner_cluster
DR partner cluster.
_links
_links
name
string
uuid
string
ha_partner
HA partner node.
_links
self_link
name
string
system_id
string
uuid
string
ha_partner_cluster
HA partner cluster.
_links
_links
name
string
uuid
string
node
_links
self_link
name
string
system_id
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
