REST API reference
Retrieve the CIFS domain preferred DC configuration for an SVM
Retrieves the preferred domain controller configuration for a CIFS domain associated with an SVM. This helps you manage domain controller preferences for optimized network performance in your storage environment.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain preferred DC configuration of an SVM.
  • vserver cifs domain preferred-dc show
fqdn
string
query
False
Filter by fqdn
server_ip
string
query
False
Filter by server_ip
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of CIFS preferred domain controller records.
records
array[cifs_domain_preferred_dc]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
