REST API reference
Retrieve the CIFS domain preferred DC configuration for an SVM
GET /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers
Introduced In: 9.10
Retrieves the CIFS domain preferred DC configuration of an SVM.
  • vserver cifs domain preferred-dc show
  • vserver cifs domain preferred-dc check
need_status
boolean
query
False
Retrieves the status of the preferred DCs.
  • Default value:
  • Introduced in: 9.12
svm.name
string
query
False
Filter by svm.name
  • Introduced in: 9.16
server_ip
string
query
False
Filter by server_ip
status.details
string
query
False
Filter by status.details
status.reachable
boolean
query
False
Filter by status.reachable
fqdn
string
query
False
Filter by fqdn
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of CIFS preferred domain controller records.
records
array[cifs_domain_preferred_dc]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4",
      "status": {
        "details": "Response time (msec): 111",
        "reachable": 1
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
status
Status of CIFS preferred domain controller.
details
string
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'.
reachable
boolean
Indicates whether or not the domain controller is reachable.
self
svm
_links
_links
name
string
uuid
string
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
status
status
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
