Retrieve the CIFS domain preferred DC configuration for an SVM
Retrieves the CIFS domain preferred DC configuration for an SVM to understand how domain controllers are prioritized within your storage virtual machine environment.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain preferred DC configuration of an SVM.
Related ONTAP commands
vserver cifs domain preferred-dc show -
vserver cifs domain preferred-dc check
need_status |
boolean |
query |
False |
Retrieves the status of the preferred DCs.
server_ip |
string |
query |
False |
Filter by server_ip |
fqdn |
string |
query |
False |
Filter by fqdn |
svm.name |
string |
query |
False |
Filter by svm.name
status.details |
string |
query |
False |
Filter by status.details
status.reachable |
boolean |
query |
False |
Filter by status.reachable
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of CIFS preferred domain controller records. |
records |
array[cifs_domain_preferred_dc] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"fqdn": "test.com",
"server_ip": "4.4.4.4",
"status": {
"details": "Response time (msec): 111",
"reachable": 1
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
status
Status of CIFS preferred domain controller.
details |
string |
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'. |
reachable |
boolean |
Indicates whether or not the domain controller is reachable. |
_links
self |
svm
_links |
name |
string |
uuid |
string |
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address. |
status |
Status of CIFS preferred domain controller. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
