REST API reference
Retrieve the CIFS domain preferred DC configuration for an SVM
Retrieves the preferred domain controller configuration for a CIFS domain associated with an SVM. This helps you understand which domain controllers are designated as preferred for handling CIFS requests.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain preferred DC configuration of an SVM.
  • vserver cifs domain preferred-dc show
  • vserver cifs domain preferred-dc check
need_status
boolean
query
False
Retrieves the status of the preferred DCs.
  • Default value:
  • Introduced in: 9.12
fqdn
string
query
False
Filter by fqdn
status.reachable
boolean
query
False
Filter by status.reachable
status.details
string
query
False
Filter by status.details
server_ip
string
query
False
Filter by server_ip
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of CIFS preferred domain controller records.
records
array[cifs_domain_preferred_dc]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4",
      "status": {
        "details": "Response time (msec): 111",
        "reachable": 1
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
status
Status of CIFS preferred domain controller.
details
string
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'.
reachable
boolean
Indicates whether or not the domain controller is reachable.
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
status
status
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
