REST API reference
Retrieve an S3 group configuration
Accesses the configuration details of an S3 group's storage virtual machine (SVM). This helps you understand the current setup and manage storage resources effectively.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/groups
Introduced in
ONTAP 9.8
Usage notes
Retrieves the S3 group's SVM configuration.
  • vserver object-store-server group show
users.name
string
query
False
Filter by users.name
  • maxLength: 64
  • minLength: 1
name
string
query
False
Filter by name
  • maxLength: 128
  • minLength: 1
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 0
policies.name
string
query
False
Filter by policies.name
  • maxLength: 128
  • minLength: 1
id
integer
query
False
Filter by id
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_group]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "Admin group",
      "id": 5,
      "name": "Admin-Group",
      "policies": [
          "name": "Policy1"
      "svm": {
        "name": "svm1",
      "users": [
          "name": "user-1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
policies
_links
_links
name
string
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
_links
_links
name
string
The name of the SVM.
uuid
string
users
_links
_links
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
s3_group
This is a container for S3 user groups.
comment
string
Can contain any additional information about the group being created or modified.
id
integer
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped.
name
string
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
policies
array[policies]
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies.
svm
svm
users
array[users]
Specifies the list of users who belong to the group.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
