REST API reference
Retrieve the S3 group configuration
Retrieves the S3 group's SVM configuration to view the current setup for your object storage environment.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/groups
Introduced in
ONTAP 9.8
  • vserver object-store-server group show
name
string
query
False
Filter by name
  • maxLength: 128
  • minLength: 1
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 0
svm.name
string
query
False
Filter by svm.name
users.name
string
query
False
Filter by users.name
  • maxLength: 64
  • minLength: 1
policies.name
string
query
False
Filter by policies.name
  • maxLength: 128
  • minLength: 1
id
integer
query
False
Filter by id
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "Admin group",
      "id": 5,
      "name": "Admin-Group",
      "policies": [
          "name": "Policy1"
      "svm": {
        "name": "svm1",
      "users": [
          "name": "user-1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
policies
_links
_links
name
string
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
_links
_links
name
string
The name of the SVM.
uuid
string
users
_links
_links
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
s3_group
This is a container for S3 user groups.
comment
string
Can contain any additional information about the group being created or modified.
id
integer
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped.
name
string
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
policies
array[policies]
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies.
svm
svm
users
array[users]
Specifies the list of users who belong to the group.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
