Retrieve an S3 group configuration
Retrieves the S3 group's configuration to understand the current setup of the SVM for managing object storage services.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/groups
Introduced in
ONTAP 9.8
Usage notes
Retrieves the S3 group's SVM configuration.
Related ONTAP commands
vserver object-store-server group show
Learn more
users.name |
string |
query |
False |
Filter by users.name
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name
id |
integer |
query |
False |
Filter by id |
policies.name |
string |
query |
False |
Filter by policies.name
comment |
string |
query |
False |
Filter by comment
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_group] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"comment": "Admin group",
"id": 5,
"name": "Admin-Group",
"policies": [
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
_links
self |
policies
_links |
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm
_links |
name |
string |
uuid |
string |
users
_links |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
s3_group
This is a container for S3 user groups.
comment |
string |
Can contain any additional information about the group being created or modified. |
id |
integer |
Specifies a unique Group ID used to identify a particular group. This parameter should not be specified in the POST or PATCH method. A Group ID is automatically generated and it is retrieved using the GET method. Group ID is SVM-scoped. |
name |
string |
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
policies |
array[policies] |
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies. |
svm |
users |
array[users] |
Specifies the list of users who belong to the group. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
