REST API reference
Retrieve multi-admin-verify requests
Retrieves multi-admin-verify requests to access information about pending administrative actions requiring multiple approvals. This helps ensure that administrative operations meet compliance or security protocols.
HTTP method and endpoint
GET /security/multi-admin-verify/requests
Introduced in
ONTAP 9.11
user_requested
string
query
False
Filter by user_requested
index
integer
query
False
Filter by index
approve_time
string
query
False
Filter by approve_time
approved_users
string
query
False
Filter by approved_users
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
state
string
query
False
Filter by state
potential_approvers
string
query
False
Filter by potential_approvers
user_vetoed
string
query
False
Filter by user_vetoed
query
string
query
False
Filter by query
create_time
string
query
False
Filter by create_time
pending_approvers
integer
query
False
Filter by pending_approvers
permitted_users
string
query
False
Filter by permitted_users
comment
string
query
False
Filter by comment
required_approvers
integer
query
False
Filter by required_approvers
operation
string
query
False
Filter by operation
execution_expiry_time
string
query
False
Filter by execution_expiry_time
approve_expiry_time
string
query
False
Filter by approve_expiry_time
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[multi_admin_verify_request]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "approve_expiry_time": "string",
      "approve_time": "string",
      "approved_users": [
        "string"
      "comment": "string",
      "create_time": "string",
      "execution_expiry_time": "string",
      "index": 0,
      "operation": "string",
      "owner": {
        "name": "svm1",
      "pending_approvers": 0,
      "permitted_users": [
        "string"
      "potential_approvers": [
        "string"
      "query": "string",
      "required_approvers": 0,
      "state": "string",
      "user_requested": "string",
      "user_vetoed": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
The owner of the request. This can identify the cluster or an SVM.
_links
_links
name
string
The name of the SVM.
uuid
string
approve_expiry_time
string
approve_time
string
approved_users
array[string]
The users that have approved the request.
comment
string
Optional user-provided comment that is sent to the approval-group email indicating why the request was made.
create_time
string
string
index
integer
Unique index that represents a request.
operation
string
The command to execute.
owner
owner
pending_approvers
integer
The number of approvers remaining that are required to approve.
permitted_users
array[string]
List of users that can execute the operation once approved. If not set, any authorized user can perform the operation.
potential_approvers
array[string]
The users that are able to approve the request.
query
string
Identifies the specific entry upon which the user wants to operate.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
state
string
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required.
user_requested
string
The user that created the request. Automatically set by ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
user_vetoed
string
The user that vetoed the request.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
