Retrieve multi-admin-verify requests
Retrieves multi-admin-verify requests to examine the status and details of ongoing verification processes across multiple administrators. This helps ensure that actions requiring multiple approvals are tracked and managed effectively.
HTTP method and endpoint
GET /security/multi-admin-verify/requests
Introduced in
ONTAP 9.11
operation |
string |
query |
False |
Filter by operation |
user_requested |
string |
query |
False |
Filter by user_requested |
state |
string |
query |
False |
Filter by state |
execution_expiry_time |
string |
query |
False |
Filter by execution_expiry_time |
execute_on_approval |
boolean |
query |
False |
Filter by execute_on_approval
comment |
string |
query |
False |
Filter by comment |
permitted_users |
string |
query |
False |
Filter by permitted_users |
pending_approvers |
integer |
query |
False |
Filter by pending_approvers |
approve_time |
string |
query |
False |
Filter by approve_time |
user_vetoed |
string |
query |
False |
Filter by user_vetoed |
create_time |
string |
query |
False |
Filter by create_time |
query |
string |
query |
False |
Filter by query |
index |
integer |
query |
False |
Filter by index |
owner.name |
string |
query |
False |
Filter by owner.name |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
potential_approvers |
string |
query |
False |
Filter by potential_approvers |
required_approvers |
integer |
query |
False |
Filter by required_approvers |
approve_expiry_time |
string |
query |
False |
Filter by approve_expiry_time |
approved_users |
string |
query |
False |
Filter by approved_users |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[multi_admin_verify_request] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"approve_expiry_time": "string",
"approve_time": "string",
"approved_users": [
"string"
"comment": "string",
"create_time": "string",
"execution_expiry_time": "string",
"index": 0,
"operation": "string",
"owner": {
"name": "svm1",
"pending_approvers": 0,
"permitted_users": [
"string"
"potential_approvers": [
"string"
"query": "string",
"required_approvers": 0,
"state": "string",
"user_requested": "string",
"user_vetoed": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
The owner of the request. This can identify the cluster or an SVM.
_links |
name |
string |
uuid |
string |
string |
approve_time |
string |
approved_users |
array[string] |
The users that have approved the request. |
comment |
string |
Optional user-provided comment that is sent to the approval-group email indicating why the request was made. |
create_time |
string |
boolean |
Specifies that the operation is executed automatically on final approval. |
string |
index |
integer |
Unique index that represents a request. |
operation |
string |
The command to execute. |
owner |
The owner of the request. This can identify the cluster or an SVM. |
pending_approvers |
integer |
The number of approvers remaining that are required to approve. |
permitted_users |
array[string] |
List of users that can execute the operation once approved. If not set, any authorized user can perform the operation. |
array[string] |
The users that are able to approve the request. |
query |
string |
Identifies the specific entry upon which the user wants to operate. |
integer |
The number of required approvers, excluding the user that made the request. |
state |
string |
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required. |
user_requested |
string |
The user that created the request. Automatically set by ONTAP.
user_vetoed |
string |
The user that vetoed the request. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
