REST API reference
Retrieve multi-admin-verify requests
Retrieves multi-admin-verify requests to review and manage administrative actions that require multiple approvals.
HTTP method and endpoint
GET /security/multi-admin-verify/requests
Introduced in
ONTAP 9.11
approved_users
string
query
False
Filter by approved_users
execution_expiry_time
string
query
False
Filter by execution_expiry_time
query
string
query
False
Filter by query
potential_approvers
string
query
False
Filter by potential_approvers
pending_approvers
integer
query
False
Filter by pending_approvers
comment
string
query
False
Filter by comment
execute_on_approval
boolean
query
False
Filter by execute_on_approval
  • Introduced in: 9.13
approve_expiry_time
string
query
False
Filter by approve_expiry_time
index
integer
query
False
Filter by index
required_approvers
integer
query
False
Filter by required_approvers
user_requested
string
query
False
Filter by user_requested
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
approve_time
string
query
False
Filter by approve_time
user_vetoed
string
query
False
Filter by user_vetoed
operation
string
query
False
Filter by operation
create_time
string
query
False
Filter by create_time
state
string
query
False
Filter by state
permitted_users
string
query
False
Filter by permitted_users
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[multi_admin_verify_request]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "approve_expiry_time": "string",
      "approve_time": "string",
      "approved_users": [
        "string"
      "comment": "string",
      "create_time": "string",
      "execution_expiry_time": "string",
      "index": 0,
      "operation": "string",
      "owner": {
        "name": "svm1",
      "pending_approvers": 0,
      "permitted_users": [
        "string"
      "potential_approvers": [
        "string"
      "query": "string",
      "required_approvers": 0,
      "state": "string",
      "user_requested": "string",
      "user_vetoed": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
The owner of the request. This can identify the cluster or an SVM.
_links
_links
name
string
uuid
string
approve_expiry_time
string
approve_time
string
approved_users
array[string]
The users that have approved the request.
comment
string
Optional user-provided comment that is sent to the approval-group email indicating why the request was made.
create_time
string
execute_on_approval
boolean
Specifies that the operation is executed automatically on final approval.
string
index
integer
Unique index that represents a request.
operation
string
The command to execute.
owner
owner
pending_approvers
integer
The number of approvers remaining that are required to approve.
permitted_users
array[string]
List of users that can execute the operation once approved. If not set, any authorized user can perform the operation.
potential_approvers
array[string]
The users that are able to approve the request.
query
string
Identifies the specific entry upon which the user wants to operate.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
state
string
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required.
user_requested
string
The user that created the request. Automatically set by ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
  • x-nullable: true
user_vetoed
string
The user that vetoed the request.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
