Retrieve multi-admin-verify requests
Retrieves multi-admin verification requests to review pending administrative actions requiring multiple approvals.
HTTP method and endpoint
GET /security/multi-admin-verify/requests
Introduced in
ONTAP 9.11
Usage notes
Retrieves multi-admin-verify requests.
permitted_users |
string |
query |
False |
Filter by permitted_users |
user_requested |
string |
query |
False |
Filter by user_requested |
operation |
string |
query |
False |
Filter by operation |
user_vetoed |
string |
query |
False |
Filter by user_vetoed |
execution_expiry_time |
string |
query |
False |
Filter by execution_expiry_time |
approve_time |
string |
query |
False |
Filter by approve_time |
execute_on_approval |
boolean |
query |
False |
Filter by execute_on_approval
create_time |
string |
query |
False |
Filter by create_time |
state |
string |
query |
False |
Filter by state |
approve_expiry_time |
string |
query |
False |
Filter by approve_expiry_time |
query |
string |
query |
False |
Filter by query |
required_approvers |
integer |
query |
False |
Filter by required_approvers |
potential_approvers |
string |
query |
False |
Filter by potential_approvers |
index |
integer |
query |
False |
Filter by index |
pending_approvers |
integer |
query |
False |
Filter by pending_approvers |
comment |
string |
query |
False |
Filter by comment |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
approved_users |
string |
query |
False |
Filter by approved_users |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[multi_admin_verify_request] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"approve_expiry_time": "string",
"approve_time": "string",
"approved_users": [
"string"
"comment": "string",
"create_time": "string",
"execution_expiry_time": "string",
"index": 0,
"operation": "string",
"owner": {
"name": "svm1",
"pending_approvers": 0,
"permitted_users": [
"string"
"potential_approvers": [
"string"
"query": "string",
"required_approvers": 0,
"state": "string",
"user_requested": "string",
"user_vetoed": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
The owner of the request. This can identify the cluster or an SVM.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
string |
approve_time |
string |
approved_users |
array[string] |
The users that have approved the request. |
comment |
string |
Optional user-provided comment that is sent to the approval-group email indicating why the request was made. |
create_time |
string |
boolean |
Specifies that the operation is executed automatically on final approval. |
string |
index |
integer |
Unique index that represents a request. |
operation |
string |
The command to execute. |
owner |
The owner of the request. This can identify the cluster or an SVM. |
pending_approvers |
integer |
The number of approvers remaining that are required to approve. |
permitted_users |
array[string] |
List of users that can execute the operation once approved. If not set, any authorized user can perform the operation. |
array[string] |
The users that are able to approve the request. |
query |
string |
Identifies the specific entry upon which the user wants to operate. |
integer |
The number of required approvers, excluding the user that made the request. |
state |
string |
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required. |
user_requested |
string |
The user that created the request. Automatically set by ONTAP.
user_vetoed |
string |
The user that vetoed the request. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
