REST API reference
Retrieve the file clone split status of all volumes in the node
Retrieves the split status of file clones for all volumes in the node to monitor ongoing clone operations and manage storage resources effectively.
HTTP method and endpoint
GET /storage/file/clone/split-status
Introduced in
ONTAP 9.10
Usage notes
Retrieves file clone split status of all volumes in the node.
Learn More
  • [DOC /storage/file/clone]
# The API:
/api/storage/file/clone/split-status
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-status" -H "accept: application/hal+json"
# The response:
"records": [
    "volume": {
      "uuid": "ac559964-57a3-40cf-b5cb-f3cb99151a7d",
      "name": "vol1",
          "href": "/api/storage/volumes/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
    "svm": {
      "name": "vs1"
    "pending_splits": 0,
    "unsplit_clone_size": 0,
        "href": "/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
    "volume": {
      "uuid": "32d95d48-d8b7-11eb-a41d-005056bb3837",
      "name": "vs1_root",
          "href": "/api/storage/volumes/32d95d48-d8b7-11eb-a41d-005056bb3837"
    "svm": {
      "name": "vs1"
        "href": "/api/storage/file/clone/split-status/32d95d48-d8b7-11eb-a41d-005056bb3837"
"num_records": 2,
    "href": "/api/storage/file/clone/split-status"
pending_splits
integer
query
False
Filter by pending_splits
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
unsplit_clone_size
integer
query
False
Filter by unsplit_clone_size
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[split_status]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
split_status
_links
self_link
pending_splits
integer
Specifies the number of pending file clone split operations in the volume.
svm
svm
unsplit_clone_size
integer
Specifies the space occupied by unsplit file clones in the volume.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
