REST API reference
Retrieve file clone split status of all volumes in the node
Retrieves the file clone split status of all volumes in the node to monitor and manage split operations efficiently. This helps you ensure data consistency and optimize storage resource allocation.
HTTP method and endpoint
GET /storage/file/clone/split-status
Introduced in
ONTAP 9.10
Learn More
  • [DOC /storage/file/clone]
# The API:
/api/storage/file/clone/split-status
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-status" -H "accept: application/hal+json"
# The response:
"records": [
    "volume": {
      "uuid": "ac559964-57a3-40cf-b5cb-f3cb99151a7d",
      "name": "vol1",
          "href": "/api/storage/volumes/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
    "svm": {
      "uuid": "9fcb44bf-4305-11e8-b8d5-00a09887594b",
      "name": "vs1"
          "href": "/api/svm/svms/9fcb44bf-4305-11e8-b8d5-00a09887594b"
    "pending_splits": 0,
    "unsplit_size": 0,
        "href": "/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
    "volume": {
      "uuid": "32d95d48-d8b7-11eb-a41d-005056bb3837",
      "name": "vs1_root",
          "href": "/api/storage/volumes/32d95d48-d8b7-11eb-a41d-005056bb3837"
    "svm": {
      "name": "vs1"
    "unsplit_size": 0,
        "href": "/api/storage/file/clone/split-status/32d95d48-d8b7-11eb-a41d-005056bb3837"
"num_records": 2,
    "href": "/api/storage/file/clone/split-status"
volume.uuid
string
query
False
Filter by volume.uuid
volume.name
string
query
False
Filter by volume.name
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
pending_splits
integer
query
False
Filter by pending_splits
unsplit_size
integer
query
False
Filter by unsplit_size
  • Introduced in: 9.15
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[split_status]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "svm": {
        "name": "svm1",
      "unsplit_size": 0,
      "volume": {
        "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
split_status
_links
self_link
pending_splits
integer
Specifies the number of pending file clone split operations in the volume.
svm
svm
unsplit_size
integer
Specifies the space occupied by unsplit file clones in the volume.
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
