Retrieve file clone split status of all volumes in the node
Retrieves the file clone split status for all volumes in the node. Use this information to monitor and manage the split operations of file clones effectively.
HTTP method and endpoint
GET /storage/file/clone/split-status
Introduced in
ONTAP 9.10
Usage notes
Retrieves file clone split status of all volumes in the node.
Learn More
DOC /storage/file/clone]
# The API:
/api/storage/file/clone/split-status
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-status" -H "accept: application/hal+json"
# The response:
"records": [
"volume": {
"uuid": "ac559964-57a3-40cf-b5cb-f3cb99151a7d",
"name": "vol1",
"href": "/api/storage/volumes/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
"svm": {
"name": "vs1"
"pending_splits": 0,
"unsplit_clone_size": 0,
"href": "/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
"volume": {
"uuid": "32d95d48-d8b7-11eb-a41d-005056bb3837",
"name": "vs1_root",
"href": "/api/storage/volumes/32d95d48-d8b7-11eb-a41d-005056bb3837"
"svm": {
"name": "vs1"
"href": "/api/storage/file/clone/split-status/32d95d48-d8b7-11eb-a41d-005056bb3837"
"num_records": 2,
"href": "/api/storage/file/clone/split-status"
pending_splits |
integer |
query |
False |
Filter by pending_splits |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
unsplit_clone_size |
integer |
query |
False |
Filter by unsplit_clone_size |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[split_status] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
split_status
_links |
pending_splits |
integer |
Specifies the number of pending file clone split operations in the volume. |
svm |
integer |
Specifies the space occupied by unsplit file clones in the volume. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
