Retrieve file clone split status of all volumes in the node
Retrieves the file clone split status for all volumes on a node to monitor the progress of ongoing clone operations. This information helps you manage and optimize storage resources effectively.
HTTP method and endpoint
GET /storage/file/clone/split-status
Introduced in
ONTAP 9.10
Usage notes
Retrieves file clone split status of all volumes in the node.
Learn More
DOC /storage/file/clone]
# The API:
/api/storage/file/clone/split-status
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-status" -H "accept: application/hal+json"
# The response:
"records": [
"volume": {
"uuid": "ac559964-57a3-40cf-b5cb-f3cb99151a7d",
"name": "vol1",
"href": "/api/storage/volumes/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
"svm": {
"name": "vs1"
"pending_splits": 0,
"unsplit_size": 0,
"href": "/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
"volume": {
"uuid": "32d95d48-d8b7-11eb-a41d-005056bb3837",
"name": "vs1_root",
"href": "/api/storage/volumes/32d95d48-d8b7-11eb-a41d-005056bb3837"
"svm": {
"name": "vs1"
"unsplit_size": 0,
"href": "/api/storage/file/clone/split-status/32d95d48-d8b7-11eb-a41d-005056bb3837"
"num_records": 2,
"href": "/api/storage/file/clone/split-status"
unsplit_size |
integer |
query |
False |
Filter by unsplit_size
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
pending_splits |
integer |
query |
False |
Filter by pending_splits |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[split_status] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
"unsplit_size": 0,
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
split_status
_links |
pending_splits |
integer |
Specifies the number of pending file clone split operations in the volume. |
svm |
unsplit_size |
integer |
Specifies the space occupied by unsplit file clones in the volume. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
