Retrieve Snapshot copy policy schedules
Retrieves Snapshot copy policy schedules to review the timing and frequency settings of your Snapshot copies. This helps you ensure that your data protection strategies align with your storage policies.
HTTP method and endpoint
GET /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced in
ONTAP 9.8
Usage notes
Retrieves a collection of Snapshot copy policy schedules.
Related ONTAP commands
snapshot policy show
snapshot_policy.uuid |
string |
path |
True |
Snapshot copy policy UUID |
snapshot_policy.name |
string |
query |
False |
Filter by snapshot_policy.name |
count |
integer |
query |
False |
Filter by count |
snapmirror_label |
string |
query |
False |
Filter by snapmirror_label |
schedule.uuid |
string |
query |
False |
Filter by schedule.uuid |
schedule.name |
string |
query |
False |
Filter by schedule.name |
prefix |
string |
query |
False |
Filter by prefix |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapshot_policy_schedule] |
"next": {
"href": "/api/resourcelink"
"records": [
"prefix": "string",
"schedule": {
"name": "weekly",
"snapmirror_label": "string",
"snapshot_policy": {
"name": "default",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapshot_policy
This is a reference to the Snapshot copy policy.
_links |
name |
string |
uuid |
string |
The Snapshot copy policy schedule object is associated with a Snapshot copy policy and it defines the interval at which Snapshot copies are created and deleted.
_links |
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
snapshot_policy |
This is a reference to the Snapshot copy policy. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
