REST API reference
Retrieve Snapshot copy policy schedules
Retrieves a collection of Snapshot copy policy schedules to understand the scheduling details for your Snapshot operations.
HTTP method and endpoint
GET /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced in
ONTAP 9.8
  • snapshot policy show
string
path
True
Snapshot copy policy UUID
snapshot_policy.name
string
query
False
Filter by snapshot_policy.name
count
integer
query
False
Filter by count
schedule.uuid
string
query
False
Filter by schedule.uuid
schedule.name
string
query
False
Filter by schedule.name
prefix
string
query
False
Filter by prefix
snapmirror_label
string
query
False
Filter by snapmirror_label
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapshot_policy_schedule]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "prefix": "string",
      "schedule": {
        "name": "weekly",
      "snapmirror_label": "string",
      "snapshot_policy": {
        "name": "default",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapshot_policy
This is a reference to the Snapshot copy policy.
_links
_links
name
string
uuid
string
The Snapshot copy policy schedule object is associated with a Snapshot copy policy and it defines the interval at which Snapshot copies are created and deleted.
_links
_links
count
integer
The number of Snapshot copies to maintain for this schedule.
prefix
string
The prefix to use while creating Snapshot copies at regular intervals.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
snapshot_policy
snapshot_policy
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
