REST API reference
Retrieve snapshot policy schedules
Retrieves a list of snapshot policy schedules to examine the timing and frequency of snapshot creation within your storage environment. This helps you understand and manage data protection strategies effectively.
HTTP method and endpoint
GET /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced in
ONTAP 9.8
Usage notes
Retrieves a collection of snapshot policy schedules.
  • snapshot policy show
string
path
True
Snapshot policy UUID
retention_period
string
query
False
Filter by retention_period
  • Introduced in: 9.12
snapshot_policy.name
string
query
False
Filter by snapshot_policy.name
count
integer
query
False
Filter by count
prefix
string
query
False
Filter by prefix
snapmirror_label
string
query
False
Filter by snapmirror_label
schedule.uuid
string
query
False
Filter by schedule.uuid
schedule.name
string
query
False
Filter by schedule.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapshot_policy_schedule]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "prefix": "string",
      "retention_period": "string",
      "schedule": {
        "name": "weekly",
      "snapmirror_label": "string",
      "snapshot_policy": {
        "name": "default",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapshot_policy
This is a reference to the snapshot policy.
_links
_links
name
string
uuid
string
The snapshot policy schedule object is associated with a snapshot policy and it defines the interval at which snapshots are created and deleted.
_links
_links
count
integer
The number of snapshots to maintain for this schedule.
prefix
string
The prefix to use while creating snapshots at regular intervals.
retention_period
string
The retention period of snapshots for this schedule.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
snapshot_policy
snapshot_policy
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
