Retrieve snapshot policy schedules
Retrieves a collection of snapshot policy schedules to review and manage how snapshots are scheduled in your environment.
HTTP method and endpoint
GET /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced in
ONTAP 9.8
Related ONTAP commands
snapshot policy show
snapshot_policy.uuid |
string |
path |
True |
Snapshot policy UUID |
snapmirror_label |
string |
query |
False |
Filter by snapmirror_label
retention_period |
string |
query |
False |
Filter by retention_period
schedule.uuid |
string |
query |
False |
Filter by schedule.uuid |
schedule.name |
string |
query |
False |
Filter by schedule.name |
count |
integer |
query |
False |
Filter by count |
prefix |
string |
query |
False |
Filter by prefix |
snapshot_policy.name |
string |
query |
False |
Filter by snapshot_policy.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapshot_policy_schedule] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"prefix": "string",
"retention_period": "string",
"schedule": {
"name": "weekly",
"snapmirror_label": "string",
"snapshot_policy": {
"name": "default",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapshot_policy
This is a reference to the snapshot policy.
_links |
name |
string |
uuid |
string |
The snapshot policy schedule object is associated with a snapshot policy and it defines the interval at which snapshots are created and deleted.
_links |
count |
integer |
The number of snapshots to maintain for this schedule. |
prefix |
string |
The prefix to use while creating snapshots at regular intervals. |
retention_period |
string |
The retention period of snapshots for this schedule. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
snapshot_policy |
This is a reference to the snapshot policy. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
