REST API reference
Retrieve transfer status of volumes in an SVM
Retrieves the transfer status of volumes within a Storage Virtual Machine (SVM) to monitor or assess current data transfer activities.
HTTP method and endpoint
GET /svm/migrations/{svm_migration.uuid}/volumes
Introduced in
ONTAP 9.10
Usage notes
Retrieves the transfer status of the volumes in the SVM.
  • vserver migrate show-volume
svm_migration.uuid
string
path
True
Migration UUID
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm_migration_volume]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "errors": [
          "message": "string"
      "node": {
        "name": "node1",
      "svm": {
        "name": "svm1",
      "transfer_state": "string",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
errors
Specifies failure codes and messages.
code
integer
Message code
message
string
Detailed message of warning or error.
self
node
Node in the destination cluster where the volume is hosted
_links
_links
name
string
uuid
string
svm
SVM information
_links
_links
name
string
The name of the SVM.
uuid
string
volume
Volume information in the destination cluster
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
Volume transfer information
_links
self_link
errors
array[errors]
List of transfer errors
healthy
boolean
Indicates whether the volume transfer relationship is healthy.
node
node
svm
svm
SVM information
transfer_state
string
Status of the transfer.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
