Retrieve the transfer status of volumes in an SVM
GET /svm/migrations/{svm_migration.uuid}/volumes
Introduced In: 9.10
Retrieves the transfer status of the volumes in the SVM.
Related ONTAP commands
vserver migrate show-volume
svm_migration.uuid |
string |
path |
True |
Migration UUID |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[svm_migration_volume] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"errors": [
"code": "string",
"message": "string"
"node": {
"name": "node1",
"svm": {
"name": "svm1",
"transfer_state": "string",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13172783 |
Migrate RDB lookup failed |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self_link
self |
errors
code |
string |
Argument code |
message |
string |
Message argument |
_links
self |
node
Node in the destination cluster where the volume is hosted
_links |
name |
string |
uuid |
string |
svm
SVM information
_links |
name |
string |
uuid |
string |
volume
Volume information in the destination cluster
_links |
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
Volume transfer information
_links |
errors |
array[errors] |
List of transfer errors |
healthy |
boolean |
Indicates whether the volume transfer relationship is healthy. |
node |
Node in the destination cluster where the volume is hosted |
svm |
SVM information |
transfer_state |
string |
Status of the transfer. |
volume |
Volume information in the destination cluster |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
