Retrieve the transfer status of volumes in an SVM
Retrieves the transfer status of volumes in an SVM to monitor data migration progress and manage storage resources effectively.
HTTP method and endpoint
GET /svm/migrations/{svm_migration.uuid}/volumes
Introduced in
ONTAP 9.10
Related ONTAP commands
vserver migrate show-volume
svm_migration.uuid |
string |
path |
True |
Migration UUID |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[svm_migration_volume] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"errors": [
"code": "string",
"message": "string"
"node": {
"name": "node1",
"svm": {
"name": "svm1",
"transfer_state": "string",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13172783 |
Migrate RDB lookup failed |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self_link
self |
errors
code |
string |
Argument code |
message |
string |
Message argument |
_links
self |
node
Node in the destination cluster where the volume is hosted
_links |
name |
string |
uuid |
string |
svm
SVM information
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
Volume information in the destination cluster
_links |
name |
string |
The name of the volume. |
uuid |
string |
Volume transfer information
_links |
errors |
array[errors] |
List of transfer errors |
healthy |
boolean |
Indicates whether the volume transfer relationship is healthy. |
node |
Node in the destination cluster where the volume is hosted |
svm |
SVM information |
transfer_state |
string |
Status of the transfer. |
volume |
Volume information in the destination cluster |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
