REST API reference
Retrieve the transfer status of volumes in an SVM
Retrieves the transfer status of volumes in a Storage Virtual Machine (SVM) to monitor and manage data movement activities effectively.
HTTP method and endpoint
GET /svm/migrations/{svm_migration.uuid}/volumes
Introduced in
ONTAP 9.10
Usage notes
Retrieves the transfer status of the volumes in the SVM.
  • vserver migrate show-volume
svm_migration.uuid
string
path
True
Migration UUID
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm_migration_volume]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "errors": [
          "code": "string",
          "message": "string"
      "node": {
        "name": "node1",
      "svm": {
        "name": "svm1",
      "transfer_state": "string",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
errors
code
string
Argument code
message
string
Message argument
self
node
Node in the destination cluster where the volume is hosted
_links
_links
name
string
uuid
string
svm
SVM information
_links
_links
name
string
The name of the SVM.
uuid
string
volume
Volume information in the destination cluster
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
Volume transfer information
_links
self_link
errors
array[errors]
List of transfer errors
healthy
boolean
Indicates whether the volume transfer relationship is healthy.
node
node
svm
svm
SVM information
transfer_state
string
Status of the transfer.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
