REST API reference
Retrieve SVM peer relationships
Retrieves information about SVM peer relationships to understand how SVMs are interconnected within your ONTAP environment. Use this endpoint to gain insight into peer configurations and manage cross-cluster operations effectively.
HTTP method and endpoint
GET /svm/peers
Introduced in
ONTAP 9.6
Usage notes
Retrieves the list of SVM peer relationships.
  • vserver peer show
The following examples show how to retrieve a collection of SVM peer relationships based on a query.
  1. Retrieves a list of SVM peers of a specific local SVM
 GET "/api/svm/peers/?svm.name=VS1"
  1. Retrieves a list of SVM peers of a specific cluster peer
 GET "/api/svm/peers/?peer.cluster.name=cluster2"
Learn more
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
uuid
string
query
False
Filter by uuid
applications
string
query
False
Filter by applications
name
string
query
False
Filter by name
peer.cluster.uuid
string
query
False
Filter by peer.cluster.uuid
peer.cluster.name
string
query
False
Filter by peer.cluster.name
peer.svm.uuid
string
query
False
Filter by peer.svm.uuid
peer.svm.name
string
query
False
Filter by peer.svm.name
state
string
query
False
Filter by state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm_peer]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "applications": [
        "snapmirror",
        "lun_copy"
      "force": null,
      "name": "string",
      "peer": {
        "cluster": {
          "name": "cluster2",
          "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
        "svm": {
          "name": "svm1",
      "state": "peered",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error codes Description
26345578
Internal error. Unable to retrieve local or peer SVM name.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
peer
Details for a peer SVM object.
cluster
cluster
svm
svm
svm
Local SVM details
_links
_links
name
string
uuid
string
svm_peer
An SVM peer relation object.
_links
_links
applications
array[string]
A list of applications for an SVM peer relation.
name
string
A peer SVM alias name to avoid a name conflict on the local cluster.
peer
peer
state
string
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relation, PATCH the state to "suspended". To resume a suspended SVM peer relation, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH.
svm
svm
Local SVM details
uuid
string
SVM peer relation UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
