Retrieve SVM peer relationships
GET /svm/peers
Introduced In: 9.6
Retrieves the list of SVM peer relationships.
Related ONTAP commands
vserver peer show
The following examples show how to retrieve a collection of SVM peer relationships based on a query.
Retrieves a list of SVM peers of a specific local SVM
GET "/api/svm/peers/?svm.name=VS1"
Retrieves a list of SVM peers of a specific cluster peer
GET "/api/svm/peers/?peer.cluster.name=cluster2"
Learn more
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
name  |
string  |
query  |
False  |
Filter by name  |
applications  |
string  |
query  |
False  |
Filter by applications  |
uuid  |
string  |
query  |
False  |
Filter by uuid  |
peer.svm.name  |
string  |
query  |
False  |
Filter by peer.svm.name  |
peer.svm.uuid  |
string  |
query  |
False  |
Filter by peer.svm.uuid  |
peer.cluster.uuid  |
string  |
query  |
False  |
Filter by peer.cluster.uuid  |
peer.cluster.name  |
string  |
query  |
False  |
Filter by peer.cluster.name  |
state  |
string  |
query  |
False  |
Filter by state  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[svm_peer]  |
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "applications": [
        "snapmirror",
        "lun_copy"
      "force": true,
      "name": "string",
      "peer": {
        "cluster": {
          "name": "cluster2",
          "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
        "svm": {
          "name": "svm1",
      "state": "peered",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578  |
Internal error. Unable to retrieve local or peer SVM name.  |
9896086  |
Peer SVM name conflicts with one of the following: a peer SVM in an existing SVM peer relationship, a local SVM, or an IPSpace. Use the "name" property to uniquely specify the peer SVM alias name.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
cluster
_links  |
name  |
string  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
peer
Details for a peer SVM object.
cluster  |
svm  |
SVM, applies only to SVM-scoped objects.  |
svm
Local SVM details
_links  |
name  |
string  |
uuid  |
string  |
svm_peer
An SVM peer relationship object.
_links  |
applications  |
array[string]  |
A list of applications for an SVM peer relationship.  |
name  |
string  |
A peer SVM alias name to avoid a name conflict on the local cluster.  |
peer  |
Details for a peer SVM object.  |
state  |
string  |
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relationship, PATCH the state to "suspended". To resume a suspended SVM peer relationship, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH.  |
svm  |
Local SVM details  |
uuid  |
string  |
SVM peer relationship UUID  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
