Retrieve SVM peer relationships
Retrieves SVM peer relationships to view existing peer configurations between Storage Virtual Machines. This information is useful for managing and auditing connections between different SVMs.
HTTP method and endpoint
GET /svm/peers
Introduced in
ONTAP 9.6
Usage notes
Retrieves the list of SVM peer relationships.
Related ONTAP commands
vserver peer show
The following examples show how to retrieve a collection of SVM peer relationships based on a query.
Retrieves a list of SVM peers of a specific local SVM
GET "/api/svm/peers/?svm.name=VS1"
Retrieves a list of SVM peers of a specific cluster peer
GET "/api/svm/peers/?peer.cluster.name=cluster2"
Learn more
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
name |
string |
query |
False |
Filter by name |
uuid |
string |
query |
False |
Filter by uuid |
applications |
string |
query |
False |
Filter by applications |
state |
string |
query |
False |
Filter by state |
peer.cluster.name |
string |
query |
False |
Filter by peer.cluster.name |
peer.cluster.uuid |
string |
query |
False |
Filter by peer.cluster.uuid |
peer.svm.name |
string |
query |
False |
Filter by peer.svm.name |
peer.svm.uuid |
string |
query |
False |
Filter by peer.svm.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[svm_peer] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"applications": [
"snapmirror",
"lun_copy"
"force": true,
"name": "string",
"peer": {
"cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
"state": "peered",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
9896086 |
Peer SVM name conflicts with one of the following: a peer SVM in an existing SVM peer relationship, a local SVM, or an IPSpace. Use the "name" property to uniquely specify the peer SVM alias name. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
peer
Details for a peer SVM object.
cluster |
svm |
svm
Local SVM details
_links |
name |
string |
uuid |
string |
svm_peer
An SVM peer relationship object.
_links |
applications |
array[string] |
A list of applications for an SVM peer relationship. |
name |
string |
A peer SVM alias name to avoid a name conflict on the local cluster. |
peer |
Details for a peer SVM object. |
state |
string |
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relationship, PATCH the state to "suspended". To resume a suspended SVM peer relationship, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH. |
svm |
Local SVM details |
uuid |
string |
SVM peer relationship UUID |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
