Retrieve SVM peer relationships
Retrieves SVM peer relationships to understand the connections between storage virtual machines (SVMs) within your ONTAP environment. This information is useful for managing and monitoring SVM interactions and dependencies.
HTTP method and endpoint
GET /svm/peers
Introduced in
ONTAP 9.6
Usage notes
Retrieves the list of SVM peer relationships.
Related ONTAP commands
vserver peer show
The following examples show how to retrieve a collection of SVM peer relationships based on a query.
Retrieves a list of SVM peers of a specific local SVM
GET "/api/svm/peers/?svm.name=VS1"
Retrieves a list of SVM peers of a specific cluster peer
GET "/api/svm/peers/?peer.cluster.name=cluster2"
Learn more
peer.svm.uuid |
string |
query |
False |
Filter by peer.svm.uuid |
peer.svm.name |
string |
query |
False |
Filter by peer.svm.name |
peer.cluster.uuid |
string |
query |
False |
Filter by peer.cluster.uuid |
peer.cluster.name |
string |
query |
False |
Filter by peer.cluster.name |
applications |
string |
query |
False |
Filter by applications |
name |
string |
query |
False |
Filter by name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
state |
string |
query |
False |
Filter by state |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[svm_peer] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"applications": [
"snapmirror",
"lun_copy"
"force": true,
"name": "string",
"peer": {
"cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
"state": "peered",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
peer
Details for a peer SVM object.
cluster |
svm |
svm
Local SVM details
_links |
name |
string |
uuid |
string |
svm_peer
An SVM peer relation object.
_links |
applications |
array[string] |
A list of applications for an SVM peer relation. |
name |
string |
A peer SVM alias name to avoid a name conflict on the local cluster. |
peer |
Details for a peer SVM object. |
state |
string |
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relation, PATCH the state to "suspended". To resume a suspended SVM peer relation, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH. |
svm |
Local SVM details |
uuid |
string |
SVM peer relation UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
