REST API reference
Updates the data svm configured as a tunnel for active directory based authentication for cluster user accounts
learn more
  • [doc /security/authentication/cluster/ad-proxy](#docs-security-security_authentication_cluster_ad-proxy)
  • [doc /security/accounts](#docs-security-security_accounts)
PATCH /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Updates the data SVM configured as a tunnel for Active Directory based authentication for cluster user accounts.
  • security login domain-tunnel modify
Request Body
Name Type Description
_links
_links
svm
svm
Example request
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default, Error
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
_links
_links
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
