REST API reference
Update a data SVM configured as a tunnel
PATCH /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Updates the data SVM configured as a tunnel for Active Directory based authentication for cluster user accounts.
  • security login domain-tunnel modify
Request Body
Name Type Description
_links
_links
svm
svm
Example request
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default, Error
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
_links
_links
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
