REST API reference
Update a data SVM configured as a tunnel
PATCH /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Updates the data SVM configured as a tunnel for Active Directory based authentication for cluster user accounts.
  • security login domain-tunnel modify
Request Body
Name Type Description
svm
svm
Example request
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621516
This operation is only supported on a data SVM.
2621706
The specified svm.uuid and svm.name refer to different SVMs.
string
svm
name
string
uuid
string
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
