Update a data SVM configured as a tunnel
Updates the configuration of a data SVM set up as a tunnel, which is used for Active Directory-based authentication for cluster user accounts.
HTTP method and endpoint
PATCH /security/authentication/cluster/ad-proxy
Introduced in
ONTAP 9.7
Usage notes
Updates the data SVM configured as a tunnel for Active Directory based authentication for cluster user accounts.
Related ONTAP commands
security login domain-tunnel modify
Request Body
| Name | Type | Description |
svm |
Example request
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621516 |
This operation is only supported on a data SVM. |
2621706 |
The specified |
href |
string |
_links
svm
name |
string |
uuid |
string |
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
