Updates ipsec configuration via rest apis
PATCH /security/ipsec
Introduced In: 9.8
Updates IPsec configuration via REST APIs.
Related ONTAP commands
'security ipsec config modify'
Request Body
| Name | Type | Description |
enabled |
boolean |
Indicates whether or not IPsec is enabled. |
replay_window |
integer |
Replay window size in packets, where 0 indicates that the relay window is disabled. |
Example request
"replay_window": 0
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66256898 |
Internal error. Failed to enable IPsec. |
66256899 |
Internal error. Failed to disable IPsec. |
66257199 |
IPsec is not supported in the current cluster version. |
href |
string |
self_link
ipsec
Manages IPsec configuration via REST APIs.
enabled |
boolean |
replay_window |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
