REST API reference
Update an IPsec configuration
PATCH /security/ipsec
Introduced In: 9.8
Updates IPsec configuration via REST APIs.
Optional properties
  • 'enabled' - Enable IPsec.
  • 'replay_window' - Replay window size in packets.
  • 'offload_enabled' - Enable IPsec hardware offload.
  • 'security ipsec config modify'
Request Body
Name Type Description
enabled
boolean
Indicates whether or not IPsec is enabled.
offload_enabled
boolean
Indicates whether or not IPsec hardware offload is enabled.
replay_window
integer
Replay window size in packets, where 0 indicates that the relay window is disabled.
Example request
  "replay_window": 0
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
66256898
Internal error. Failed to enable IPsec.
66256899
Internal error. Failed to disable IPsec.
66256913
Offload setting changes are not allowed when IPsec is enabled.
66256915
Anti-replay protection and IPsec offload cannot be operational at the same time.
66257007
Failed to update replay window size.
66257199
IPsec is not supported in the current cluster version.
66257496
IPsec must be enabled to support BGP peer groups with MD5. Disable MD5 first in the BGP peer group.
string
ipsec
Manages IPsec configuration via REST APIs.
enabled
boolean
offload_enabled
boolean
replay_window
integer
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
