REST API reference
Update an IPsec configuration
Updates the IPsec configuration to modify the security settings for network communications. This is useful when you need to adjust encryption settings or manage secure connections.
HTTP method and endpoint
PATCH /security/ipsec
Introduced in
ONTAP 9.8
Usage notes
Updates IPsec configuration via REST APIs.
  • 'security ipsec config modify'
Request Body
Name Type Description
enabled
boolean
Indicates whether or not IPsec is enabled.
replay_window
integer
Replay window size in packets, where 0 indicates that the relay window is disabled.
Example request
  "replay_window": 0
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
66256898
Internal error. Failed to enable IPsec.
66256899
Internal error. Failed to disable IPsec.
66257007
Failed to update replay window size.
66257199
IPsec is not supported in the current cluster version.
string
ipsec
Manages IPsec configuration via REST APIs.
enabled
boolean
replay_window
integer
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
