Update an IPsec configuration
Updates the IPsec configuration to adjust security settings for network communications. Use this endpoint when you need to modify IPsec parameters, such as enabling hardware offload or setting the replay window size.
HTTP method and endpoint
PATCH /security/ipsec
Introduced in
ONTAP 9.8
Usage notes
Updates IPsec configuration via REST APIs.
Optional properties
'enabled' - Enable IPsec.
'replay_window' - Replay window size in packets.
'offload_enabled' - Enable IPsec hardware offload.
Related ONTAP commands
'security ipsec config modify'
Request Body
| Name | Type | Description |
enabled |
boolean |
Indicates whether or not IPsec is enabled. |
offload_enabled |
boolean |
Indicates whether or not IPsec hardware offload is enabled. |
replay_window |
integer |
Replay window size in packets, where 0 indicates that the relay window is disabled. |
Example request
"replay_window": 0
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66256898 |
Internal error. Failed to enable IPsec. |
66256899 |
Internal error. Failed to disable IPsec. |
66256913 |
Offload setting changes are not allowed when IPsec is enabled. |
66256915 |
Anti-replay protection and IPsec offload cannot be operational at the same time. |
66257007 |
Failed to update replay window size. |
66257199 |
IPsec is not supported in the current cluster version. |
66257496 |
IPsec must be enabled to support BGP peer groups with MD5. Disable MD5 first in the BGP peer group. |
href |
string |
self_link
ipsec
Manages IPsec configuration via REST APIs.
enabled |
boolean |
offload_enabled |
boolean |
replay_window |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
