REST API reference
Update SVM peer permissions
Updates the permissions for an SVM peer to modify access or capabilities shared between storage virtual machines. This operation is useful when adjusting collaboration settings or access controls within your storage environment.
HTTP method and endpoint
PATCH /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the SVM peer permissions.
  • vserver peer permission modify
Example
Updates an SVM peer permission.
PATCH "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc" '{"applications":["flexcache"]}'
cluster_peer.uuid
string
path
True
Peer cluster UUID
  • Introduced in: 9.7
svm.uuid
string
path
True
SVM UUID
Request Body
Name Type Description
applications
array[string]
A list of applications for an SVM peer relation.
Example request
  "applications": [
    "snapmirror",
    "flexcache"
Status: 200, Ok
applications
array[string]
  "applications": [
    "snapmirror",
    "flexcache"
Status: Default
ONTAP Error Response Codes
Error codes Description
26345572
{field} is a required field.
26345574
Failed to find the SVM or volume name with UUID.
string
cluster_peer
Peer cluster details
name
string
uuid
string
svm
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".
name
string
The name of the SVM.
uuid
string
svm_peer_permission
Manage SVM peer permissions.
applications
array[string]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
