REST API reference
Update SVM peer permissions
PATCH /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced In: 9.6
Updates the SVM peer permissions.
  • vserver peer permission modify
Example
Updates an SVM peer permission.
PATCH "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc" '{"applications":["flexcache"]}'
cluster_peer.uuid
string
path
True
Peer cluster UUID
  • Introduced in: 9.7
svm.uuid
string
path
True
SVM UUID
Request Body
Name Type Description
applications
array[string]
A list of applications for an SVM peer relationship.
Example request
  "applications": [
    "snapmirror",
    "flexcache"
Status: 200, Ok
applications
array[string]
  "applications": [
    "snapmirror",
    "flexcache"
Status: Default
ONTAP Error Response Codes
Error codes Description
26345572
{field} is a required field.
26345574
Failed to find the SVM or volume name with UUID.
9896059
SVM peer permission does not exist.
string
cluster_peer
Peer cluster details
name
string
uuid
string
svm
Local SVM permitted for peer relationship. To create peer permissions for all SVMs, specify the SVM name as "*".
name
string
uuid
string
svm_peer_permission
Manage SVM peer permissions.
applications
array[string]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
