Updates the svm peer permissions
example
updates an svm peer permission <br/>
patch "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc" {"applications":["flexcache"]}
<br/>
# learn more
* [doc /svm/peer-permissions](#docs-svm-svm_peer-permissions)
PATCH /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced In: 9.6
Updates the SVM peer permissions.
Related ONTAP commands
vserver peer permission modify
Example
Updates an SVM peer permission.
PATCH "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc" '{"applications":["flexcache"]}'
Learn more
cluster_peer.uuid |
string |
path |
True |
Peer cluster UUID
svm.uuid |
string |
path |
True |
SVM UUID |
Request Body
| Name | Type | Description |
applications |
array[string] |
A list of applications for an SVM peer relation. |
Example request
"applications": [
"snapmirror",
"flexcache"
Status: 200, Ok
applications |
array[string] |
"applications": [
"snapmirror",
"flexcache"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345572 |
{field} is a required field. |
26345574 |
Failed to find the SVM or volume name with UUID. |
href |
string |
_links
cluster_peer
Peer cluster details
name |
string |
uuid |
string |
svm
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".
name |
string |
The name of the SVM. |
uuid |
string |
svm_peer_permission
Manage SVM peer permissions.
applications |
array[string] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
