Update SVM peer permissions
Updates the permissions for an SVM peer to adjust access to specific applications or resources. This is useful when you need to modify peer relationships to reflect changes in access requirements or configurations.
HTTP method and endpoint
PATCH /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the SVM peer permissions.
Related ONTAP commands
vserver peer permission modify
Example
Updates an SVM peer permission.
PATCH "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc" '{"applications":["flexcache"]}'
Learn more
cluster_peer.uuid |
string |
path |
True |
Peer cluster UUID
svm.uuid |
string |
path |
True |
SVM UUID |
Request Body
| Name | Type | Description |
applications |
array[string] |
A list of applications for an SVM peer relationship. |
Example request
"applications": [
"snapmirror",
"flexcache"
Status: 200, Ok
applications |
array[string] |
"applications": [
"snapmirror",
"flexcache"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345572 |
{field} is a required field. |
26345574 |
Failed to find the SVM or volume name with UUID. |
9896059 |
SVM peer permission does not exist. |
href |
string |
_links
cluster_peer
Peer cluster details
name |
string |
uuid |
string |
svm
Local SVM permitted for peer relationship. To create peer permissions for all SVMs, specify the SVM name as "*".
name |
string |
uuid |
string |
svm_peer_permission
Manage SVM peer permissions.
applications |
array[string] |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
