REST API reference
Re-key the external key in the key hierarchy for an SVM
Rekeys the external key in the key hierarchy for an SVM that uses a Google Cloud KMS configuration. This operation is typically used when you need to update the encryption key for enhanced security management.
HTTP method and endpoint
POST /security/gcp-kms/{gcp_kms.uuid}/rekey-external
Introduced in
ONTAP 9.11
Usage notes
Rekeys the external key in the key hierarchy for an SVM with a Google Cloud KMS configuration.
  • security key-manager external gcp rekey-external
gcp_kms.uuid
string
path
True
UUID of the existing Google Cloud KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
key_name
string
Key identifier of the Google Cloud KMS key encryption key.
svm
svm
Example request
  "key_name": "cryptokey1",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
65537721
Google Cloud KMS is not configured for the given SVM.
65537729
External rekey failed on one or more nodes. Use the REST API POST method "/api/security/gcp-kms/{uuid}/rekey-external" to try the rekey operation again.
string
svm
name
string
The name of the SVM.
uuid
string
gcp_kms_key
key_name
string
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
