Re-key the external key in the key hierarchy for an SVM
Rekeys the external key in the key hierarchy for an SVM when using a Google Cloud KMS configuration. Use this endpoint to update the external key, ensuring the security of your data encryption process.
HTTP method and endpoint
POST /security/gcp-kms/{gcp_kms.uuid}/rekey-external
Introduced in
ONTAP 9.11
Usage notes
Rekeys the external key in the key hierarchy for an SVM with a Google Cloud KMS configuration.
Related ONTAP commands
security key-manager external gcp rekey-external
gcp_kms.uuid |
string |
path |
True |
UUID of the existing Google Cloud KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_name |
string |
Key identifier of the Google Cloud KMS key encryption key. |
Example request
"key_name": "cryptokey1"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537556 |
ONTAP is not able to successfully encrypt or decrypt because the configured external key manager for this SVM is in a blocked state. Possible reasons for a blocked state include the top-level external key protection key not found, disabled or having insufficient privileges. |
65537721 |
Google Cloud KMS is not configured for the given SVM. |
65537729 |
External rekey failed on one or more nodes. Use the REST API POST method "/api/security/gcp-kms/{uuid}/rekey-external" to try the rekey operation again. |
gcp_kms_key
key_name |
string |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
