Re-key the external key in the key hierarchy for an SVM
Rekeys the external key in the key hierarchy for an SVM with a Google Cloud KMS configuration to maintain secure access and encryption practices.
HTTP method and endpoint
POST /security/gcp-kms/{gcp_kms.uuid}/rekey-external
Introduced in
ONTAP 9.11
Related ONTAP commands
security key-manager external gcp rekey-external
gcp_kms.uuid |
string |
path |
True |
UUID of the existing Google Cloud KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_name |
string |
Key identifier of the Google Cloud KMS key encryption key. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
Example request
"key_name": "cryptokey1",
"scope": "string",
"svm": {
"name": "svm1",
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537721 |
Google Cloud KMS is not configured for the given SVM. |
65537729 |
External rekey failed on one or more nodes. Use the REST API POST method "/api/security/gcp-kms/{uuid}/rekey-external" to try the rekey operation again. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
gcp_kms_key
key_name |
string |
scope |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
